Old 10-08-2021, 11:50 PM
Originally Posted by MosportGreen66 View Post
100% need the name of it...
https://www.summitracing.com/parts/otc-6494
Billohio (10-09-2021), jasonL78 (10-11-2021)
  #12
Old 10-09-2021, 12:58 PM
napa68 napa68 is offline
Finished up some brake work on this Thunderbird......
The Following 4 Users Say Thank You to napa68 For This Useful Post:
dykstra (10-10-2021), markinnaples (11-08-2021), RPOLS3 (10-11-2021), Too Many Projects (10-14-2021)
  #13
Old 10-09-2021, 05:02 PM
Billohio Billohio is online now
We keep getting showers or fog and can't harvest soybeans, so I painted the grill in this thing today
Bill
The Following 10 Users Say Thank You to Billohio For This Useful Post:
69M22Z (11-08-2021), dykstra (10-10-2021), Jonesy (10-10-2021), L16pilot (10-09-2021), MosportGreen66 (10-12-2021), RPOLS3 (10-11-2021), scuncio (10-09-2021), SS427 (10-09-2021), tom406 (10-09-2021), Xplantdad (10-09-2021)
  #14
Old 10-09-2021, 10:49 PM
R68GTO R68GTO is online now
Default Actually 2 days worth of work
Worked on cleaning, sanding and polishing my vintage 3.5" Fentons. Turned out pretty good, can't wait to get the tires mounted and get these on the car.
The Following 9 Users Say Thank You to R68GTO For This Useful Post:
dykstra (10-10-2021), L_e_e (10-10-2021), olredalert (10-10-2021), PeteLeathersac (10-14-2021), RPOLS3 (10-11-2021), scuncio (10-11-2021), SuperNovaSS (10-16-2021), Too Many Projects (10-14-2021), Xplantdad (10-09-2021)
  #15
Old 10-09-2021, 11:15 PM
njsteve njsteve is offline
When was the last time you got to brag about your engine's actual stump-pullin' power?
I had to pull out a 15 year old Weeping Willow that was tilting toward the back side of the house due to a rotten root. I had the tree service come in and cut the tree down but leave a 4 foot tall stump so I'd have something to lever against with a chain. I used a Sawzall and some pruning blades and cut the roots within six inches of the stump and then hooked the old trusty pullin' chain to the old 396 (Diesel) Turbo-Jet. Threw it in 4WD Low and slowly yanked it out of the ground.
I then spent an hour knocking all the dirt off the root ball so I'd have something to fill in the giant crater I left. At least the dogs got something new to investigate.
The Following 6 Users Say Thank You to njsteve For This Useful Post:
Billohio (10-10-2021), dykstra (10-10-2021), L_e_e (10-10-2021), olredalert (10-10-2021), PeteLeathersac (10-10-2021), scuncio (10-11-2021)
  #16
Old 10-10-2021, 11:19 PM
dykstra's Avatar
dykstra dykstra is online now
----Assembled a really cool 6 foot tall cabinet (3 feet wide by 1 1/2 deep) and on HD castors. Polished stainless doors, and really pretty good quality. Company name is Seville Classics. For once the directions were pretty good (that was a surprise for me). Started about 2:30 as I had a doctors appointment in the morning and just finished about 20 minutes ago! Look 'em up, they are all over the internet. Got mine at Sam's Club for $199.....Bill S
Love my Seville Classics Bill!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
The Following 3 Users Say Thank You to dykstra For This Useful Post:
markinnaples (11-08-2021), olredalert (10-11-2021), RPOLS3 (10-11-2021)
  #17
Old 10-14-2021, 02:25 AM
Slow getting back to posting. Work has been progressing on the '68 Mustang at work.
I use drill screws to pull the toe board tight to the frame flange, so I'm not welding to air between.
Blurry pic of clamping the apron tight to the rail for welding.
I had to cut out a piece of the frame extension to slide the new rail in. The holes for plug welding are what was missing from the previous install. Not having a dozen welds to drill out made the removal easy, but there is a lot of structural strength here that was missing before too.
Another blurry pic, looks like the camera focused on the exhaust pipe...sorry.
Torque box that was installed. The flange was supposed to be welded to the frame too. It was barely tacked and then a patch put over it and welded to the torque box. I cleaned all the crap off and spent time properly fitting it to the frame.
Holes drilled for plug welding.
Welded to the bottom of the frame extension too.
Locating the new radius rod bracket for welding.
Rail replacement complete. New lower control arm, upper ball joint and radius rod bushings. I need to do that to the right side too, but AFTER I install the engine/trans. The left was a major fight with no weight to hold the body while installing the spring again.
Got the engine/trans in today and motor mounts and crossmember tightened up. Installing the steering gear, center link, idler arm, tie rods and that danged power assist valve and slave as a unit was a lot harder than taking it out !!
dykstra (10-15-2021), PeteLeathersac (10-14-2021)
  #18
Old 10-14-2021, 02:41 AM
A week ago, I had a pad built for the new shed. Friday, I spent the day leveling it and setting the 4 skids for the floor frame and Sunday, built the frame and set the floor panels. 12X16, big enough to park one of my cars in, but it's for all my lawn care equipment that will fill it. I will section off a 5X8 corner for a potting shed.
Old 10-14-2021, 03:12 PM
touspude touspude is offline
Default Lovely
Wow! It's beautiful!
The Following User Says Thank You to touspude For This Useful Post:
  #20
Old 10-16-2021, 01:27 AM
It just got new tracks and I could have bought a decent camaro for that. Not much you can do.
It has a 500hp engine with a tune up!
Bill
