Old 12-28-2021, 01:03 PM
CamaroNOS CamaroNOS is offline
Originally Posted by MarcDant View Post
Paul you could probably check with a telescopic camera thru the hole on top were switch mounts into, with a bright light along the bottom welded seam and you can make this cheap air dryer and remove a lot of moisture that would otherwise settle on the bottom of compressor.
Thanks Marc, I will look into that.
I appreciate you reminding us all about the dangers of air pressure.
Paul
