Old 02-16-2022, 03:46 AM
Canuck's Avatar
Canuck Canuck is offline
Default Rear end ID
Trying to identify this 12 bolt that was used as a roller in my 71 442. Can’t seem to find anything on the RE code. The K indicates it was made by MCKinnon in Ontario and likely for a GMCanada application. I have no need for this but did not want to junk it if there is some value to someone.
www.vancouverclassiccars.com
Old 02-16-2022, 11:57 AM
'71 Olds would have the Olds 8.5 10 bolt, which has a 12 bolt cover. It's not the same as the Chevy 12 bolt. A picture of the whole rear end, including the cover, would help.
Old 02-16-2022, 07:33 PM
Zman1969 Zman1969 is offline
Thumbs up
Freddie I know inside they do look like a 8.5 but bigger! like on steroids! seems like in 70-72 there were several different rear ends each division had till they settled on the 8.5" rear in 71 and 72 like Chevelle and Pontiac were their own 8.2" and the cutlass skylarks got 8.5" Crazy!
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 02-16-2022, 10:43 PM
The Olds rear end actually is a 8.5, but not the same as the corporate 8.5 that went into production in '71. The ring gear is 8 1/2 inches in diameter, the same as the corporate 8.5. The Olds rear end was only used in the Cutlass and 442 from '68 to '70.
Old 02-16-2022, 01:55 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Pulled a couple Chevy style 12 Bolts out of Canadian Cutlasses over the years... not sure why but they were in there. Some 69's for certain.
70 Chevelle SS-454 LS-5 M-22
Old 02-16-2022, 01:57 PM
L78_Nova's Avatar
To clarify, most were the O style but the odd one seemed to be a Chevy style
Old 02-16-2022, 04:00 PM
Canuck's Avatar
To clarify this is a chev 12 bolt that was in my car,not original to the car and not going back in. I only need to know to see if it appeals to someone looking for a 12 bolt for buildup purposes.
Old 02-16-2022, 07:23 PM
There is always value in an original Chev 12 bolt, even if it's only $200 as a buildable core.
The E may represent an Eaton posi. Do you know if it is a posi and what the ratio is ?
I sold a core 12 bolt on here last fall and shipped it to TX via Fastenal.
Zman1969 (02-16-2022)
Old 02-16-2022, 10:33 PM
Casting date and casting number on the pumpkin?
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 02-17-2022, 04:12 AM
Canuck's Avatar
Guys
Appreciate all the info about what went into an Olds from the factory. I already know that.
My question is; Does anybody know what the RE code is for on a Canadian built GM 12 bolt as described in the first post.
