Old 02-20-2022, 03:19 PM
x44d80 x44d80 is offline
In the pictures you can see the slight cleanup in the intakes down only about 1 1/2". The small screw holes I believe had a tag per the machinist but who knows. The other holes had air hose couplers. The original owner said they ran hot water into the block because the aluminum motor lost heat to fast.
