Old 07-18-2022, 03:14 AM
Default Can anyone ID this Radiator?
Any ideas what it's for?
Attachments - The Supercar Registry IMG_3189.jpg IMG_3188.jpg IMG_3187.jpg IMG_3186.jpg
Old 07-18-2022, 03:53 AM
LT1vette LT1vette is offline
42 Ford... just a guess LOL
Old 07-18-2022, 01:59 PM
----With an AC condenser on the front? I don't think so, but may be for some sort of big commercial vehicle.....Bill S
Old 07-18-2022, 02:58 PM
Looks like something from the late 50s early 60s with factory air.
With all the little key holes punched in it, you have to wonder if it was an aftermarket unit?
That giant oversize tank on the top reminds me of the radiator on my Vandan Plas Princess limo. My radiator interchanges with RR and Bentley model limos from the day, as they were all built by the same coach builder.
But on the british limos the upper tank is a much different shape.
Old 07-19-2022, 12:40 PM
Camaro Dave Camaro Dave is offline
Looks like a 32 Ford, or early 30's ford hot rod radiator
1967 RS/SS 350 CONVERTIBLE
1968 Z/28 CONCOURSE CORRECT POP
1970 L78
1971 RS/SS 350
1972 RS
1989 IROC
1972 VEGA WAGON 350 671 BLOWER
1956 BEL AIR CONVERTIBLE
1970 442 CONVERTIBLE CLONE 502/502 700R4
The Following User Says Thank You to Camaro Dave For This Useful Post:
dustinm (07-19-2022)
Old 07-20-2022, 07:26 PM
galveston's Avatar
galveston galveston is offline
That's for a '33 - '34 ford, you can tell by the radiator grill shell mounting tabs on the top in front of the filler neck. Add on A/C condenser.
'32's had mounting holes in the lower side tabs and a offset filler neck.
Shaun
The Following User Says Thank You to galveston For This Useful Post:
Xplantdad (07-20-2022)
Old 07-26-2022, 09:49 AM
Thanks All!
Old 07-26-2022, 03:29 PM
67since67's Avatar
For use with a some later engine than a flathead V8 though, as the flatty had separate water pumps for each bank and the rad had two upper and two lower outlets/inlets.
