Old 05-08-2023, 01:48 PM
William William is offline
Default Caveat Emptor...block stamp
https://www.ebay.com/itm/145071564766
124379L525822
From the ad:
1969 Chevy Camaro REAL DEAL SS350 numbers matching rebuilt 350.
Pic of block stamping shows 19L525822 T0219HC
HC is an L65 350/2 barrel w/manual trans
Was not a Camaro SS.
The Following 3 Users Say Thank You to William For This Useful Post:
dykstra (05-08-2023), X66 714 (05-08-2023), Xplantdad (05-08-2023)
Old 05-08-2023, 02:20 PM
Hotrodpaul Hotrodpaul is online now
Has a 6000 rpm redline tach and if original would denote a Z-28 or 396 L-78 solid lifter engine.
Old 05-08-2023, 02:23 PM
Added; dash cluster not trimmed for a clock.
The Following User Says Thank You to William For This Useful Post:
Old 05-08-2023, 04:44 PM
Five leaf springs, could denote a big block? Seller does not show the firewall to see if it has a big block heater core. Also check for blacked out tail panel clues.
Old 05-08-2023, 06:47 PM
A little off course here.
The original, VIN-stamped block shows an HC code, 350 2-barrel carb. NOT an SS.
Old 05-08-2023, 08:32 PM
It appears the C was stamped later than the assy stamp judging by its depth. Do you suspect it could be a mistake or a restamp of some sort? I think it best to inspect this car in person.
Old 05-08-2023, 10:09 PM
Consignor has verified it is HC and removed Camaro SS references.
Hats off to Dean's Hot Rods!
The Following 4 Users Say Thank You to William For This Useful Post:
John (05-09-2023), PeteLeathersac (05-09-2023), scuncio (05-08-2023), Xplantdad (05-08-2023)
Old 05-08-2023, 11:40 PM
Well, that's one in a row.
southernfriedcj (05-09-2023)
