Old 12-11-2023, 05:13 AM
69L78's Avatar
69L78 69L78 is offline
Default Can this 302 block be repaired?
I am looking at buying a 68 Z and the original block that comes with the car is cracked, I was told years ago it could not be repaired, but now with today's technology it could be. If it can be repaired, what would be the cost?
Old 12-11-2023, 05:22 AM
Sleeve and a helicoil/thread insert should take care of it.
Jason
Old 12-11-2023, 11:43 AM
Yes, it can be repaired. A sleeve will take care of the cylinder. Cast iron crack repair plugs should take care of the deck. A Jergens thread insert will fix the hole. Talk to a good machine shop and get their opinion because they will be the ones to do the work.
Indy Cylinder Heads had an oven that they used to weld cylinder heads. I don't know if they can do blocks too, but you might ask.
Old 12-11-2023, 12:02 PM
69L78's Avatar
Thanks for all the responses. I am in PA so I have a few choice machine shops to consider. When the engine failed years ago, it ruined the cylinder head so I am looking for a single 291 head dated no later that June 12, 1968
Old 12-17-2023, 12:47 AM
69 Post Sedan's Avatar
They do it all the time t our local machine shop…..they can “pin it” without any issues. It may have to be sleeved as others have mentioned.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-06-2024, 06:28 AM
Tuna Joe Tuna Joe is offline
The go to guys for cast iron repair is Lock and Stitch located in Turlock CA
I’m having a block repaired there currently. I’ll let you know how it comes out.
Not cheap!
http://www.locknstitch.com/index.html
The Following User Says Thank You to Tuna Joe For This Useful Post:
69M22Z (03-06-2024)
