Old 10-12-2024, 01:14 AM
In my previous shop, I ran 50' of black iron on the ceiling, with 4 moisture drops and ball valves along the system. I don't see getting enough air to properly cool the pipe with long term use to condense the moisture out of the air enclosed in a ceiling/wall. When I ran my blast cabinet for a couple hours, I had moisture all the way to the 4th drop. In an 8 hour pressure pot blasting day, I had to stop halfway thru and let the pipe cool for an hour during lunch to prevent getting moisture in the sand.
Old 10-12-2024, 02:45 PM
427yenko 427yenko is offline
Thanks for all of the replies. It seems like black pipe is the popular choice for doing this installation. I have looked at a few hdpe/aluminum offerings such as rapid air and was hoping that they were good options as they seem very simple to install. I have schedule 80 pvc in my current garage and I know some people cringe at the thought of using something like that because of the bursting danger. It has been installed for more than 10 years now and I do not have any leaks of any consideration. I wanted to upgrade from that material and do this right while hoping the more cumbersome installation of rigid and heavy pipe would not be necessary. I may be overstating the concern with this method, but lightweight bendable tubing sure has an appeal.
Old 10-12-2024, 02:57 PM
396 SS/RS's Avatar
396 SS/RS 396 SS/RS is offline
Originally Posted by 169indy View Post
My "Rapid-Air" Plastic system has Constant issues, Sad I went this route now.
"MAXLINE" system.
I'm curious as to what issues you are having?
I installed this system in my shop about 3 years ago with 4 air connections and found it to be trouble free. I would recommend it from my personal experience.
FWIW, I do not leave the lines charged, I close the outlet valve at the tank at night as I don't use it daily.
Good Judgement comes from Experience. Some Experience comes from Bad Judgement" Albert Einstein
Old 10-12-2024, 03:09 PM
I installed the rapid air in my shop as well. I was easy to install and has been trouble free for the couple years I have had it installed.
Jason
396 SS/RS (10-12-2024)
  #15
Old 10-12-2024, 10:34 PM
1/2" schedule 80 pvc is rated to 850 psi. I don't see an issue with bursting at piston compressor capabilities.
Old 10-12-2024, 11:20 PM
lbnaz lbnaz is offline
Yenko Premier Member
I have been a Union Steamfitter for 48 years now 39 of which I worked at the trade. All of the systems mentioned will work in a shop. I personally used 3/4" (7/8" od) type L copper with sweat joints, dirt legs, and valves for blow off on all my drops. My compressor runs at a 125 psi in the system. The use of black iron sch 40 pipe is used industry wide in most commercial applications and is highly recommended. It resists breakage, bumps, tugs, etc. on the system. PVC is subject to burst with any of the same. Just my 2 cents.
The Following User Says Thank You to lbnaz For This Useful Post:
X66 714 (10-12-2024)
  #17
Old 10-12-2024, 11:43 PM
It is also not UV protected. If you run it in the shop exposed to light, it will rot eventually.
I know I am REALLY the oddball here. I wanted something easier than black pipe. Even though I have my own threader, it is a pain cutting and threading to make it look good. When running 100 foot of natural gas line, I had to use black pipe. What a pain. It is heavy and difficult for an old man to work with.
I came across a great deal on several hundred feet of 1/2 in air brake line. Very flexible and easy to work with. If you heat the end, it stretches easily enough to get it over a pex line fitting.
It is UV protected and has a burst pressure of 1300 psi.
Talk about easy. Cut with pex cutters, heat the end with a heat gun for 20 seconds, use a brass pex fitting. Also found deals on bulk pex fittings and clamps.
My compressor has an aftercooler. I ran three loops up the wall and back down before any of the lines headed into the shop area. I have a fancy three stage dryer set up, but have never installed it. Each loop on the wall has a ball valve at the bottom. I open them every once in awhile but have NEVER seen moisture in the system. Sandblast for an hour straight, and never get moisture.
big gear head (10-14-2024)
  #18
Old 10-13-2024, 03:49 PM
Rsconv68 Rsconv68 is offline
PVC has a high burst pressure. I used a standard compressor hose due to the tight area I needed it mounted.
Old 10-13-2024, 05:26 PM
hogdaddy hogdaddy is offline
This is some good info on compressor lines and such.
https://www.about-air-compressors.com/plumbing/
67 Convertible T-1
Old 10-13-2024, 07:34 PM
iluv69s iluv69s is offline
I have all copper buried in cieling and walls with bleed valves and h2o separators at all drops. All electric chest high. Also have Luann screwed to walls and cieling as opposed to drywall for ease of future access and ease of screwing signs, etc to walls. I also put 2x10’s strategically placed between studs and behind Luann in certain areas to mount a TV, speakers, etc.
