  #32
Old 06-07-2025, 12:54 PM
chevyman0429's Avatar
chevyman0429 chevyman0429 is online now
Well after a move total house renovations having cancer twice and cutting off one of my fingers with a circular saw Im finally getting back after this car. The plans is try and match the paint on the front clip and doors and drive the snot out of it! I have a 69 ss396 post car i want to dig into but can’t do it until this one is wrapped up.
I got the front clip and drivers door on and for the most part adjusted where gaps are nice! The hood is a different story it almost touches fender on drivers side but passenger side has 3/4” gap. I think I can push drivers door in about 1/8 which would allow me to move drivers fender in about the same but I don’t believe that will be enough to close up gap on passenger side! Assembly manual says between the fender opening in back by windshield should be 56 5/8 my opening is 57”. Anyone have any advice on this ?
This car has January build date with GM factory 6,000 rpm redline tachometer cloth bench seat (originally) and column shift . I pulled dash cluster out this week to find a late 68 date code on it. The dash cluster is also from a column shift car. Which leads me to believe its original to the car but it had been restored By the Lions Club here in Michigan before the wreck!
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
The Following 4 Users Say Thank You to chevyman0429 For This Useful Post:
big gear head (06-07-2025), dykstra (06-09-2025), mhurd (06-08-2025), RPO LS7 (06-07-2025)
