Old 03-08-2008, 02:36 AM
BBIGG BLOCK 396 BBIGG BLOCK 396 is offline
Default Re: just picked up christine car..
That will make a REALLY COOL LOOKING HOTROD! If you were not so far from me I would be glad to take it off your hands!I have "KILLER 340 STROKER" that would get it moving easily. If it has the 318 engine it is the POLY as they call it and you can do some neat tricks to them! and there are some pretty neat intakes availiable from time to time. I happened to see an intake not long ago for one and it was SIX DUECES which certainly would look COOL under the hood.
Old 03-08-2008, 03:01 AM
CanadianPoncho CanadianPoncho is offline
You'll find all the info you need at www.forwardlook.net
Todd
(former owner of a 58 and miss it dearly!)
The Canadian Pontiac forum:http://www.canadianponcho.ca
The 2 Door Post forum
http://www.2doorpost.com
Old 03-08-2008, 03:38 AM
Sure looks better than the underground Tulsa one!.
Cool cars really...weren't all '57 Furys dual fours no matter which size V8?.
Old 03-08-2008, 05:15 AM
scott s scott s is offline
The tulsa car should have been barn kept like this car it would have survived much better,I just can,t believe with all the mouse poop etc and critters that probally lived in this thing for the last 30 yrs or so that the interior is not all ate up or trashed!!!Hell even the headliner is mint!!I think ill try and get it running tomorrow and see what i have..
Old 03-21-2008, 07:00 PM
Norm reynolds Norm reynolds is offline
I know a lot about 57 plymounths Its not a 318 if it is a v8 its a 272 or a 301 I had one and droped in a 1960 413 and that thing was fast as hell But the stock brakes must be upgraded the stock ones sucked and was bad to stop this beast with a big motor If I were you I would frist upgrade the brakes to disk system then drop in a 413 It will fit right in a belive me it will be fast had this back in 68 and never had a 383 road runner beat me many tried
Old 03-22-2008, 12:03 AM
More infor on 57 plymouths the plaza and the savoy models v8s all were 272s the belvederes came with 301s the fury came with the 350 witch later became the 361 the 350and the 361 look the same as the 383 the 272 and the 301 looked the same as the 318 also 57 was the frist year for the 3 speed torquflite they also came with a 2 speed powerflite
mine was a belvedere and had the 301 with the torquflite
it was given to me because it had a rod knock
I picked up a 413 out of a 1960 imperial
I used motor mounts from a 1959 Dodge that came with a 361
the frame from the 57 plymouth and the 59 dodge were the same so the mount worked great I got dule exhast from a 59 dodge 383 every thing bloted right up with out no problems
the beast was fast in the day but the stock factory brakes could just not handle 100 mph+ stops
Still had a lot of fun with it as this was my first car and it did put a lot of muscel cars back in 68 to shame man the looks I got when I blew off a 383 road runners was pricless
Today the only thing I would change would be the brakes then you would have a good runner
love to build one today the same way that 413 was a good motor and a great match for a clean 57 plymouth and will fit right in with out much of a hassle
Old 03-22-2008, 01:00 AM
here is a 57 plymouth 301
Old 03-22-2008, 01:06 AM
This 57 was at atlatic city back in 05 this one had the 440 in it [image][/image]
Old 03-22-2008, 07:20 AM
I had a older fella call me 2 nights ago. He is trying to figure out value of a 57 Plymouth 4 door 6 cyl car wth 22K miles that has not been started in 40 years. It was given to him by a relative that bought it new and parked it in the garage. He says the engine can be rotated by hand so he knows it is not seized up. I will look at it this weekend. Any guesses on value ?
Old 03-22-2008, 07:28 AM
....57 Plymouth 4 door 6 cyl car wth 22K miles that has not been started in 40 years. ...Any guesses on value ?
$5K tops if it doesn't need a lotta work, Charley.
Bill Pritchard
