Old 02-04-2020, 08:25 PM
Burd's Avatar
Burd Burd is offline
Citrus Strip is safe on most plastics.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 02-04-2020, 08:52 PM
ronzz572 ronzz572 is offline
I soaked a lot of parts in evaporust. It has always soften up the paint or removed it. Never tried it on a fan shroud. But I bet it would work. Even if it softens it and then used a high pressure air blow gun to remove what's left.
1970 L78 camaro Cortez silver ralley sport under restoration
Old 02-05-2020, 03:50 PM
L78steve L78steve is offline
Originally Posted by clnovaparts View Post
Use Super Clean. The purple gallon container. Submerge the part for best results. Plastic model builder hobbyist use it. Check out YouTube videos. Won't hurt plastic. Don't get it on your skin. Great for stripping vacumn plating (chrome) on arm rest bases, AC balls etc. Read the directions on what not to use it on.
This is the best and safest. Castrol Super Clean.
Old 02-06-2020, 04:09 AM
ss427copo's Avatar
ss427copo ss427copo is offline
I did mine and it came out perfect.
ZIP STRIP........It lifts paint right off and 0000 fine steel wool. Wash it good. DONE.
Of course, don’t try it while it’s attached. 😎
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 02-06-2020, 07:15 PM
I tried paint stripper, which turned out just fine. Used a rag and plastic scraper then washed off with soap an water. Didn't harm the plastic at all...
Old 02-09-2020, 11:57 AM
Default Paint removal off plastic
You may want to try regular lighter fluid. Do not leave on for extended period of time, just wipe on & wipe off. Use plastic cleaner soap like Super Clean or Simple Green diluted afterward for cleanup. Don.
