#11
What’s the finish on the RS solenoid nut ? Gold
#12
Gold Zinc , or phosphate?
Thanks |
#14
Excellent!
#15
Great progress!
Coil bracket had bright plating; need correct PCV and hose. Dipstick and tube should be natural steel. LH wire separator bracket should be orange. Upper control arms were painted as an assembly [less ball joint] so washers should be black. Sway bar and brackets should be black. Cowl plenum should be orange.
Learning more and more about less and less... Last edited by William; 04-13-2020 at 04:34 PM. |
The Following User Says Thank You to William For This Useful Post: | ||
ZLP955 (04-17-2020) |
#16
![]() Quote:
You are on the right track. If you want images of my Z-11 EC for comparison let me know and I will get them up. Images are a time saver for sure. |
The Following User Says Thank You to 70 copo For This Useful Post: | ||
chevyandpontiac (04-13-2020) |
#17
That would be awesome. I have looked at a lot of pictures and they have been all over the place. Thanks for sharing
#18
Here is my NOR Z-11 HB 350/300. It is not 100% factory correct however it is perfect for a driver and just about any grass show you want to go to.
Hope this helps. |
#19
Overhead
#20
Survivor example with over spray engine stop lift recall hold down- and patina.
