Old 03-20-2020, 12:55 PM
Default 1969 Camaro Pace car engine compartment
I am currently detailing engine compartment on my Pace car. It is a super nice car, but over the past 40 years a lot of parts just ended up paint black.
Can you share some pictures of either z28 or pace car engine compartment pictures that are correct. This was the starting point. I now have the fenders and wheels off. I am not looking to over restore, just make it nicer.
Thanks Dan
The Following User Says Thank You to chevyandpontiac For This Useful Post:
67since67 (03-20-2020)
Attachments - The Supercar Registry Z11 cowl.PNG Original 1969 IPC engine.jpg IMG_4638.jpg camaro.JPG
Old 03-20-2020, 01:52 PM
67since67's Avatar
Making a great car even better!!
Old 03-20-2020, 02:14 PM
This car really deserve it. It was so nice taking a car part when all the bolts come out and it is not a rusty turd with hidden secrets.
Old 03-20-2020, 03:15 PM
William William is offline
Maybe more involved than you intend, but the top of the cowl should be body color [white]. If it was rattle-canned black, may be easy to remove.
Old 03-20-2020, 08:59 PM
The cowl will be coming off so I can make that change, thanks.
Old 03-21-2020, 02:13 PM
KevinW KevinW is offline
You can fix the cowl air cleaner seal, by gently using wide painters tape and roll the seal back to the outside, leave in sun for a while. Back of seal looks great, front has mis-shapened.
69 327 convertible (driver)
Old 03-24-2020, 03:40 PM
Does any one have a good picture of the restored wiper motor? not the regular camaro one the R/S one. thanks
Old 03-26-2020, 01:12 AM
First one of the black RS/Z wiper motor... the rest are of a 26k mile white on white RS/SS conv 05A X11
Old 03-31-2020, 12:39 PM
69VN's Avatar
69VN 69VN is offline
I have a '69 SS350. Maybe these pics of my engine compartment may help you.
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
The Following 2 Users Say Thank You to 69VN For This Useful Post:
chevyandpontiac (03-31-2020), ScottG (04-01-2020)
Old 03-31-2020, 12:49 PM
A very nice example
