Old 11-09-2011, 05:17 PM
AutoInsane AutoInsane is offline
Default Valve Cover Install
Putting some nice black aluminum finned valve covers on the 304 V8 in my 74 CJ5 Jeep. Should I put RTV or some other sealant on both sides of the gasket ??
Thanks
Bill O'Brien
1974 Jeep CJ5 - 304 V8, Edelbrock Intake, Holley 650, MSD Ignition, Patriot Headers
Old 11-09-2011, 05:48 PM
elonblock elonblock is offline
Default Re: Valve Cover Install
Use a very fine layer of RTV on the gasket side which contacts the valve cover. This will help hold the gasket to the valve cover when installing.
The most important thing is to make sure the area where the gasket goes in the valve cover and the mating surface on the cylinder head are really clean for proper sealing.
Elon
69 COPO Camaro
Old 11-09-2011, 06:50 PM
good advice!
Old 11-09-2011, 10:32 PM
I usually glue my cork gaskets to the valve covers then use a thin film of white lithium grease to keep it from sticking to the cast iron head.
Old 11-09-2011, 10:59 PM
WILMASBOYL78's Avatar
Ditto on the grease...make sure the covers are clean and straight...use sealant to affix gaskets to the covers. Let them dry for awhile...I then use a light coat of wheel bearing grease on the surface that goes on the head...always works for me....don't over tighten!
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 11-09-2011, 11:00 PM
Plowman's Avatar
Plowman Plowman is offline
You will like that trick next time you service the valve cover. Paul
Old 11-09-2011, 11:28 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: WILMASBOYL78</div><div class="ubbcode-body">Ditto on the grease...make sure the covers are clean and straight...use sealant to affix gaskets to the covers. Let them dry for awhile...I then use a light coat of wheel bearing grease on the surface that goes on the head...always works for me....don't over tighten!
wilma </div></div>I would love to see those fingers get greased up Tommy. ha ha ha!
Old 11-10-2011, 04:16 PM
92646 92646 is offline
Sammy that is just not right.
Old 11-10-2011, 06:00 PM
Sammy...at least I wash my hands!!
wilma [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 11-10-2011, 06:09 PM
ORIGLS6 ORIGLS6 is offline
wilma </div></div>
Yeah, listen to the old guys. They'll give you tried-and-true advice gleaned from years and years of experience.
Did I mention that they're old? And that they have many, many, many years of experience? And that they're OLD! [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
