Old 05-20-2015, 11:48 PM
68l30's Avatar
68l30 68l30 is offline
Default Dust Covers
??? What have you guy's been using for front spindle dust covers? I'm currently in the process of metal working the dings out of my "born with" set and have a repro set on order. I'm not sure how I feel about the bright Zinc finish on the new ones. I think it needs to be toned down some to be correct. Has anyone aged or refinished them ? I may stick with my old ones once they are straight, but I need a good back up.....Used set would be nice, but they are still going to need some work.
BIG
Old 05-21-2015, 02:12 AM
SS427's Avatar
SS427 SS427 is offline
Default Re: Dust Covers
You can tone them down by giving them a very slight dusting in the bead blast cabinet. You could also remove the zinc finish altogether.
Rick Nelson
Old 05-21-2015, 02:17 AM
68l30's Avatar
Great idea, My other thought was about 15 min in the tumbler...just not long enough to leave a pattern. Not sure why this bugs me, I'm the only one who will ever see it....
BIG
Old 05-21-2015, 11:14 AM
m22mike's Avatar
m22mike m22mike is offline
Big
I just used a repop set on my Malibu I have been working on. I was doing plating anyway, so I striped off the bright zinc in phosphoric acid and had them cad plated. They are toned way down, not shiny at all.
I can shoot you a couple pic's if you want. There on the car.
Or, give them a quick dunk in the acid and rinse and inspect, repeat as need. That will dull them up a bit.
#3, strip the zinc, there will be a nice phosphoros coating on the steel, blow off with a air gun and a damp towell, force dry or hang in the sun ( you may have to go to AZ.) then treat with Rpm and leave the bare ?
Prep and Etch
Old 05-21-2015, 12:54 PM
68l30's Avatar
Thanks Mike! I'm glad I'm not crazy in thinking these are incorrect as reproduced. I'll give it a shot and see how they turn out.
BIG
Old 05-21-2015, 12:59 PM
enio45 enio45 is offline
repops are not close to the nos ones - but do work.....nos ones and assembly like correct ones are bare steel.....nos ones, if u can find them are $$$ about 200 each if i recall.
big, if you do as mike suggest ref AZ.....i hang them outside my garage for you :-)
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 05-21-2015, 01:09 PM
68l30's Avatar
LOL...You may get a package in the mail. It's getting damn cold here....
I've not thrown in the towel on my original set....still picking and peening... [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
BIG
Old 05-21-2015, 01:28 PM
SS427's Avatar
The nipple on the repops is too soft and too large and obviously the zinc in incorrect. Also I have found they usually do not fit for crap and will not hold so I have to put a series of dimples around the flange so they hold. Typical repop garbage.
Rick Nelson
Old 05-21-2015, 04:00 PM
68l30's Avatar
Nice, I have one of the old ones almost done, I had to repress the nipple in it by estimating the size. Do they ever make anything close...???
BIG
Old 05-21-2015, 04:12 PM
m22mike's Avatar
[/quote]
Eddie, bare steel ? You mean galvanized correct ? You been drinking your brothers vino again [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
