Old 09-27-2015, 05:32 PM
dvss1 dvss1 is offline
Default 70 turbo 400 cw code. what is the application
I have a turbo 400. Tag reads 70-cw. 1590 and above that is 289. Only thing I could find it fits 402 and 350 in nova and camaro. I"m hoping it fits the 396 350 engine. I have a few pictures. Any help is appreciated.
Attachments - The Supercar Registry transtagCYLS6a.jpg transtagCW2.jpg 46207.jpg 46205.jpg
Old 09-27-2015, 05:40 PM
Default Re: 70 turbo 400 cw code. what is the application
Scarce trans..1970 L-78 Chevelle-Nova assembled after Oct.16th 1969.
1970 LT-1 Nova used it too,but I think your date is too early to consider it came out of one those.
Old 09-27-2015, 08:47 PM
Is there a con VIN# stamped into the driver side machined pad above the pan,to help determine what car it originally came in?
Old 09-28-2015, 12:52 AM
x77-69z28's Avatar
Also 70 Z28. First year for turbo 400 in the Z28
Old 09-28-2015, 12:56 AM
x77-69z28's Avatar
If it still has the original converter, it has a high stall speed. I think it's 2600rpm.
Old 09-28-2015, 02:54 AM
marxjunk marxjunk is offline
should be 6 lugs on the converter... shouldnt it be?
Mark
Old 09-28-2015, 12:12 PM
WILMASBOYL78's Avatar
The CW coded TH400 will work fine behind the L34 motor...this a HD unit designed to work with the solid lifter big blocks. If you clean the case carefully you may find the letters CW printed in a pink color. These transmissions used the 6 lug convertor, hi-shift point governor and many other special internals.
The VIN is typically on the driver's side pan rail area...but, I have seen them on the bell housing on pass. side as well. As mentioned, given the date code, this could have only come from a Nova or Chevelle with L78.
Very cool part...good luck.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 09-07-2023, 11:38 PM
1970 L78 Chevelle w/CW TH400 & 1970 LS-6 Chevelle w/CY TH400.
