Old 04-08-2016, 02:32 PM
YENKO DEUCE REGISTRY's Avatar
Default Dual Quad Linkage
What would the Day 2 linkage look like for this setup, and where can I get one? This car has the steel throttle arm coming off the gas pedal, no cable
Marlin
Old 04-08-2016, 03:50 PM
Default Re: Dual Quad Linkage
For mine on my wagon, I just made one from round stock, and then joined the 2 carbs together. I think it looks good and it works great (about 5 years now) plus it was cheap to build. Here is what it looks like.
Old 04-08-2016, 05:34 PM
tjs44 tjs44 is offline
Aftermarket 409 linkage would work fine.Tom
Old 04-08-2016, 06:38 PM
I'm not sure the '09 linkage would work that well. It's designed to have a lag before opening the front carb. I'd think with a tunnel ram you'd want both carbs to work at the same time.
Verne
[img]https://www.yenko.net/ubbthreads/pics..._linkage_62_2x[/img]
Old 04-09-2016, 01:33 PM
ZAPPER68 ZAPPER68 is online now
Yenko Premier Member
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Verne_Frantz</div><div class="ubbcode-body">I'm not sure the '09 linkage would work that well. It's designed to have a lag before opening the front carb. I'd think with a tunnel ram you'd want both carbs to work at the same time.
Verne
</div></div>
Yup, you're right Verne. Both carbs need to be working at the same time. This winter I rigged my tunnel ram with the rear carb opening first and the engine definitely wanted more fuel. It kind of fell flat on it's a$$ until the front carb kicked in.
Old 04-08-2016, 06:40 PM
Hmmm... I guess I need to take a few pictures and then start looking for examples on line - I assumed that Offenhauser had an old school version that went with their intake.
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 04-08-2016, 06:51 PM
PxTx's Avatar
PxTx PxTx is offline
Search the HAMB. I would run them sideways. This is kinda cool if you are comitted to inline.
Paul III
Old 04-08-2016, 07:08 PM
Actually hadn't thought about running them sideways, just thought inline was the typical Day 2 style! Is one method easier than the other, or more true to Day 2?
Marlin
Old 04-08-2016, 07:19 PM
Marlin,
Every set up I saw back in the day was always in line. Race cars started putting them sideways. I had 2 660s in line and the linkage was super simple. I forget the brand and I don't have photos of the left side of the engine.
Verne
Old 04-11-2016, 02:30 PM
whitetop whitetop is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">Actually hadn't thought about running them sideways, just thought inline was the typical Day 2 style! Is one method easier than the other, or more true to Day 2? </div></div>
I never liked the huge, wide hole you need to cut in the hood for sideways..
Weiand still makes the best inline linkage available from Summit or Jegs
