Old 05-06-2016, 11:24 PM
Bernhard Bernhard is offline
Default Day two check list
What is on your day two checklist for your build?
69 442 post bench 3 pedal
Old 05-07-2016, 12:24 AM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Day two check list
HEADERS
Cragars
Traction / wheel hop management device
Distributor recurve and ignition upgrade
Assumptions made that you start with a Muscle car with:
4 barrel carb- prefer Holley
Decent intake manifold
Posi rear - mid 3 series gears or lower
Shifter capable of being consistent
Reliable tachometer
Could be a whole bunch more listed as nice to have...
Paul III
Old 05-07-2016, 01:49 AM
Swap out the 16" AR TTII's for 15" Cragar SS's; 15x10 rears and 14x6 fronts. Not sure if I am brave enough to run Bias Plys on it or stick with the radials and get some 295/50 R15's for the rear. The rest is pretty Day 3 or 4 already.
John 10:30
Old 05-07-2016, 02:11 PM
Pat_Dilling's Avatar
Pat_Dilling Pat_Dilling is offline
Definitely a Hurst Shifter and a Sun Tach, a set of SW gauges in a 3 panel pod under the dash. Remove the smog pump, probably did that when the headers went in. Pull the tail pipes off so the exhaust dumps in front of the rear axle, and turbo mufflers. A vintage Accel Super coil on the firewall and spark plug wires. Or, depending on era you are going for, an MSD ignition. Some sort of traction bars, Lakewood J Bolt style if you have leaf springs, maybe some ladder bars on a coil spring car.
And of course your high school graduation tassel hanging from the mirror. :-)
My '68 L72 Biscayne tribute is For Sale
My '68 Biscayne updates and fixes: http://tinyurl.com/Biscayne-My-Way
'68 Biscayne how I got it: http://tinyurl.com/Biscayne-Baseline
Old 05-09-2016, 02:26 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Aluminum Intake & Holley 3310, M/T valve covers, ET IV/Ansen Sprints, traction bars, headers & exhaust
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
