Old 07-01-2016, 10:36 PM
rcc rcc is offline
Default 70 Yenko Electrical issues--Help!!
When the car arrived, I noticed that the turn signals did not work. I found an orange/cream pigtailed wire in the trunk that was not connected. I connected it and the turn signals started to work although neither green indicator in the instrument cluster showed either light as working---that's when the real problems started!!
Now, the turn signals do not work and the running lights ( all 4, front and rear) stay continuously "ON". I had to disconnect the battery to keep it from going dead.
Ideas? Help!
Rick
1956 Bel Air Nomad
1961 Ford Starliner, the "Tangerine Dream"
1963 Olds Jetfire, 1 of 13 Fluid-Injected & Turbocharged
1966 Dodge Hemi Charger the "White Elephant"
1970 Dodge Challenger R/T, the "Cream Dream Shaker"
1970 Nova Yenko Deuce
Old 07-01-2016, 10:59 PM
Craig_Maiorana's Avatar
Craig_Maiorana Craig_Maiorana is offline
Default Re: 70 Yenko Electrical issues--Help!!
Have you tried pulling the flasher to see if it breaks connection?
I like cars more than I like people .....
Old 07-01-2016, 11:06 PM
rcc rcc is offline
I pulled both the ER and turn signal flasher relays/pods--no difference. Lights still on. I also pulled the entire headlight switch and the lights stayed on!
1956 Bel Air Nomad
Old 07-01-2016, 11:07 PM
rcc rcc is offline
I also pulled out the ER flasher on the steering column--ER flasher did not work and the running lights all stayed on!
1956 Bel Air Nomad
Old 07-01-2016, 11:35 PM
TDW TDW is offline
Did you disconnect the pigtail? If not, you have picked up a hot wire in that connection.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 07-01-2016, 11:55 PM
rcc rcc is offline
I disconnected the pigtail with no change, even after disconnecting the battery and waiting 5 minutes before reconnecting it.
1956 Bel Air Nomad
Old 07-02-2016, 01:52 PM
earntaz earntaz is offline
Rick -- check your PM box ... I sent you wiring diagrams ... Craig
Old 07-02-2016, 06:47 PM
rcc rcc is offline
Just did, Taz.
I'm grateful for all the assistance!
Rick
PS: Horns inop. Maybe the wiring harness attached to the steering column? Testing it?
1956 Bel Air Nomad
Old 07-02-2016, 07:01 PM
As I indicated before -- check that connector on the column under dash ... if the car came from the "Land Of A Thousand Lakes" it can get pretty humid up there. GREEN CRAB/CORROSION on connectors. TAZ
Old 07-03-2016, 12:57 AM
rcc rcc is offline
I separated the two parts of the wring harness that is mounted to the steering column.. I used a little fine grit sandpaper on the exposed metal tangs and then sprayed both parts with electrical cleaner. Same problem. No green indicator lights on the instrument cluster for either turn signal indicators or ER flashers.
Next, when I am not so sore from lying upside down, under the dash, for prolonged periods of time, I will check the indicator light bulbs themselves.
Sure appreciate the help.
1956 Bel Air Nomad
