Old 09-23-2017, 02:24 PM
ALLZS ALLZS is offline
Default Firewall oil line hole
Is this the correct location for a 69 camaro 4 speed car oil gauge line I was told it should be under the speedo cable ?
Old 09-23-2017, 03:03 PM
That looks correct, right behind the distributor. That's where mine is located.
Old 09-24-2017, 11:09 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
LOS or NOR built car?
Tim in NSW, Australia
Old 09-24-2017, 08:24 PM
Mine is a NOR car. The assembly manual shows it in the same place, page 416(U17)... Shouldn't matter if it's a LOS or NOR Camaro.
Old 09-24-2017, 09:40 PM
HuggerSS HuggerSS is offline
Default Oil line
For 1968, Norwood cars have the oil line to the left of the speedometer clip, LA cars have the oil line above the speedometer cable hole
Old 09-24-2017, 09:56 PM
its a june built nor car
Old 09-25-2017, 12:23 AM
ZLP955's Avatar
NOR typically followed the AIM piercing location, LOS didn't.
Old 09-25-2017, 12:37 AM
The correct oil line hole for a Norwood car is the piercing dimple that is about 1 1/2 inches to right of the AIM piercing location.
Old 09-25-2017, 01:41 AM
169indy's Avatar
169indy 169indy is offline
Sometimes "IF" at ALL. My 12E 1968 Z has an OIL line that was jammed thru the Muncie Spedo grommet in the OH Sh!T fashion of a production line,,,,,,,,,,,NO GMAD punched Oil Hole at all for my gage equipped car..... seemed they leaned out and got her done 1 min faster Ha ha
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 09-25-2017, 01:49 AM
Mine too is a June car!! You would think all plants followed the manual, that's what they were printed for?? Make sure you install a grommet and paint the line flat black, for the factory used black oil lines.
