Old 04-22-2019, 12:38 AM
R68GTO R68GTO is offline
Default Correct Hood Latch Finishes
Would like to confirm the correct finishes for the hood latch parts on both the parts that bolt to the hood and the parts that bolt to the core support brace. Is it all bare steel? Anyone have some pics of these areas on correctly restored cars? Thanks
Jim
Old 04-22-2019, 02:45 AM
cheveslakr cheveslakr is online now
It was gray phosphate, both pieces. Some have painted the catch spring black but I've never seen an original that showed signs of black paint.
Old 04-22-2019, 11:54 AM
m22mike's Avatar
m22mike m22mike is offline
The springs are black, most likely lacquer dipped.
Old 04-22-2019, 10:35 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is online now
Jim
Jim, for the hood latch mechanism on a 1969 Camaro, the portion of the assembly that bolts to the hood is zinc (medium grey) phosphate, the spring is painted full gloss black and the attaching bolts are manganese (dark grey) phosphate. The portion of the assembly that bolts to the header panel and rad support is zinc phosphate, the attaching bolts are manganese phosphate and the bolts that attach the horns (2) are either clear (silver) zinc plated or manganese phosphated. Hope that helps.
Old 04-23-2019, 01:25 AM
Jim
I'm not sure what car and year you are speaking of but based on others responding. I'm guessing they know you are speaking of a 69 Camaro only. But for others possibly reading this now or in future., this answer may differ depending on model and year.
Old 04-24-2019, 01:25 AM
Thanks for all the responses. Interestingly enough when I took mine apart the braket that bolts to the hood was gloss black on the visible surfaces (as was a lot of stuff on my car), but he surface that bolted to the hood was bare steel. The tapered head pin/bolt and spring retaining cup had gloss black paint on the surface facing toward the front of the car, but the engine side also looked like bare steel. The spring was gloss black all over which leads see to believe thats what the factory did since the backside of the pin and retainer were unpainted.
Old 04-27-2019, 04:09 PM
Correction....I took my bracket that bolts to the hold out in the daylight, and it is indeed light gray phosphate.
Old 04-29-2019, 02:12 AM
x33rs x33rs is offline
If it helps, mine is unrestored and the hood latch is in fact grey phosphate and my spring does have some black left on it.
12D Norwood car if that makes any difference. I'd post a pic but unable to do so.
Old 04-29-2019, 11:56 PM
Is the tapered head pin bare steel? How about the spring retainer cup?
Old 04-30-2019, 12:28 AM
m22mike's Avatar
Same phos plating.
