Old 09-22-2019, 11:33 PM
scuncio scuncio is offline
Default BB Chevy Nylon Timing Set - Years Used?
I have a 38,000-mile 1971 402 Impala that needs some engine work - and I'm wondering if it would have had the nylon timing gear set from the factory (in which case I'd R&R it with a new steel timing set).
Thanks,
Tony
Old 09-23-2019, 12:13 PM
luzl78 luzl78 is offline
If original then it would have the nylon.
Old 09-23-2019, 12:18 PM
Yes,GM used them throughout the 1960's/70's.Unless someone has already changed it before you,I would.
Old 09-23-2019, 08:18 PM
Thanks...guess I'll be getting on that.
Old 09-23-2019, 09:03 PM
WILMASBOYL78's Avatar
Post Timing gear/chain...
The last one I did was so loose it just about fell off in my hand when the timing cover was removed...and that was on a 33,000 mile car
Best insurance for a big block...check those valve springs, keepers etc...they can be a problem, too.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
scuncio (09-29-2019)
