Old 09-11-2020, 07:45 PM
mhm1966 mhm1966 is offline
Default Thermostat Housing Identification
Can anyone identify this thermostat housing. The number 60536065 is stamped on the underside.
Old 09-11-2020, 11:10 PM
This??
https://www.ebay.com/itm/1967-72-Ori...-/373068487687
Old 09-12-2020, 07:25 PM
Lee, that is what I was thinking. Going through GM part numbers I can't find anything that matches. Maybe the number on the thermostat housing is a casting or stamping number. Does this housing look familiar to anyone else?
Old 09-17-2020, 12:46 AM
Not sure, but that may be an aftermarket replacement for the 660 style aluminum housing. I have seen some other cast iron ones in non-GM aftermarket boxes with similar long casting numbers.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 09-17-2020, 02:09 AM
John Brown's Avatar
That one probably came from EVERCO or EVERHOT, an aftermarket supplier for all things that break or wear out in the heater and air conditioning systems in a normal car. They work, but they sure are heavy, and not to mention, ugggly.
John Brown
Old 09-20-2020, 07:45 PM
John, you sure hit the nail on the head when you said heavy.
