Old 12-05-2023, 01:45 AM
LT1vette LT1vette is offline
Default Muncie reverse cable adjustment
I needed to install a new cable on the reverse lock out on my Muncie shifter. When I adjust the cable so that the bottom blocker is sitting flush at the bottom of the handle, there is too much "slop" in the cable at the top. I have not installed the shift ball yet because I have not decided how short to cut the cable...
Anyone have some insight on this would really help me...
TIA
Old 12-07-2023, 01:52 AM
Anyone have an idea?
Old 12-07-2023, 08:15 PM
mssl72's Avatar
mssl72 mssl72 is offline
There's a spring inside the handle, right? It's been years since I've had mine apart. When you say "slop at to top", exactly what do you mean? Can you post a couple of pictures?
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 12-09-2023, 01:15 AM
I played with the shifter again today. I think I'm going to have to wait until I get the tranny in the car and do the final shifter gate alignment. Right now the lockout plug does not ALWAYS drop back into the lock out position. I've tried to align the gates, mounted the shifter on the tranny on the bench and positioned the rods in the gears. But there is still a line up problem for the reverse positioning.
Old 12-10-2023, 05:53 PM
Tarrytown SS427s Tarrytown SS427s is offline
You have to set this up with the handle removed. The lug at the bottom of the handle needs to be up inside that sleeve about 1/8” when the lockout lever is released. If you have slack then the lug is bottoming out on the shifter before the handle is fully down. This lockout has nothing to do with the rest of the shifter adjustments.
Steve
68 SS427 Custom Coupe 427/385/M21/3:73
68 Impala Custom Coupe 427/425/M21/3:73
68 Biscayne 2 Door 250/3 speed
68 Caprice Estate
68 Camaro SS396 4 speed
Tags
muncie shifter, reverse lock out
