Old 01-29-2004, 03:50 AM
Belair62 Belair62 is offline
Default 70 Pontiac or Chevelle key warn buzzer ?
O.K.,that annoying key warning buzzer keeps buzzing even with the key out when the door is open..I found this part broken under the turn signal switch inside the column...my question is...I can't find a good view of a TS switch so is this piece a part of the TS switch or seperate ? It pushes into a square hole on the inside of the column and I can't really tell if it broke off the TS switch....damn buzzer
