Old 09-15-2006, 05:19 AM
DZ Fool DZ Fool is offline
Default Fast Class / Tire Psi
What air pressure do they run in the bias tires in fast class racing
1969 Z\28 Rally Sport, Hugger Orange,White Stripes,White Vinyl,Endura Bumper,
Old 09-15-2006, 12:39 PM
Default Re: Fast Class / Tire Psi
Depends on the car, but most start out at around 40 PSI. Best way to find out is to look at the contact patch after a small burnout. If it is dark in the center and light on the outside of the tread, you have too much pressure. If it is dark on the outsides and light in the center, the tire has too little pressure and is actually buckling up in the center. I have GoodYear Eagle GTII's on my car and run 36 PSI in mine. Lays down an even dark patch across the tread width.
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 09-15-2006, 11:34 PM
BUIZILLA BUIZILLA is offline
I ran 44 in my red lines
JH
aka - Mighty Mouse
Old 09-17-2006, 08:05 PM
Chevy454 Chevy454 is offline
It will also depend on hot/cold...my tires go from roughly 41-ish psi cold (start of day) to around 46 psi post burnout/run...
Old 09-21-2006, 01:27 AM
71-LS6 71-LS6 is offline
Have gone as low as 12-14 psi (trying to get some sidewall flex), I'm usually at 26-32, that's with my light in the ass, heavy in the nose, hemi challenger. I am NOT the 60' king.
Steve H.
industrial art collector
Old 09-21-2006, 06:26 AM
retengw31 retengw31 is offline
Used to run 45, now run 40. Like a little bit of spin to avoid the small block bog. Noticed, thugh, that driving on the street with the higher pressures is really wearing down the center rib quickly on both rear tires.
1966 442- L69 4 speed
1968 Ramrod W31- bought new
1968 442 W30-real thing,but a little different
1975 Delta Royale convertible-
