Do you mean the drive pinion vertical offset?..if so it was 1.50,for the 1970 Nova at least.
what i am looking for is the angle of the differential’s pinion in relation to the driveshaft. I have installed a proshifted tremec tko 600 and it has a slight vibe on decel.
I have used 1.5 degrees to 2.0 degrees on the pinion angle for a lowered 1969 Camaro and it worked for this problem. I had another problem with vibration and hard shifting in reverse that was an alignment issue that was created by the bell housing making the input shaft bind up at the back of the crank. I have heard this is real critical with the Tremec transmission. In fact did you have the vibration before you installed the new trans?
Mark Sheppard |
Thanks for the help. It started this vibration after the tremec install.I checked to see if the input was binding it was ok.
