Had a little time today and then decided to run errands with the 360. I beat this thing like a rented mule. It’s a blast. The tunnel ram runs good. After getting fuel close to home I had to run back home to fix a few issues. The right side valve cover needed the bolts snugged up. I put a spacer on the starter as the drive was lightly touching the flywheel, it needed another throttle return spring and I had to clearance the hood a little because when the engine torqued the throttle got stuck on the hood. That was fun to find out.
Ran and got all-thread and cut it to put air filters on, then drilled the hood and mounted the Grump Lump. It’s ridiculous and I love it.
AMC weirdo Always on the lookout for neat vintage AMC performance parts. |
The Following 11 Users Say Thank You to LetsFNgo For This Useful Post: | ||
BB70 (04-18-2025), cheveslakr (04-18-2025), dykstra (04-20-2025), earntaz (05-21-2025), gtomike1967 (04-18-2025), L78_Nova (04-20-2025), markinnaples (04-19-2025), olredalert (04-17-2025), scuncio (04-17-2025), Tenney (04-18-2025), Too Many Projects (04-17-2025) |
Looks like a total blast!
The Following User Says Thank You to scuncio For This Useful Post: | ||
Pro Stock John (04-24-2025) |
Thread Tools | |
Display Modes | |
