Old 11-10-2011, 10:50 PM
Default Re: Valve Cover Install
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ORIGLS6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: WILMASBOYL78</div><div class="ubbcode-body">Ditto on the grease...make sure the covers are clean and straight...use sealant to affix gaskets to the covers. Let them dry for awhile...I then use a light coat of wheel bearing grease on the surface that goes on the head...always works for me....don't over tighten!
wilma </div></div>
Yeah, listen to the old guys. They'll give you tried-and-true advice gleaned from years and years of experience.
Did I mention that they're old? And that they have many, many, many years of experience? And that they're OLD! [img]<<GRAEMLIN_URL>>/naughty.gif[/img] </div></div>
Plus....they're OLD!
Old 11-11-2011, 06:55 AM
It seems like I should be old as long as I have had that advice [img]<<GRAEMLIN_URL>>/grin.gif[/img] (grease on gaskets, maintenance, etc) it was firmly implanted in my head [img]<<GRAEMLIN_URL>>/scholar.gif[/img] by 10 via my dad (EXP Minesweeper Navy Diesel engineer on a crew of 6 or 8) &amp; grand father (Duke Mech Engineer/WWII USS Soley Engineering Officer) SO It is OLD advice...
Survivors, restored cars, &amp; other photos
Old 11-11-2011, 10:17 PM
Plowman's Avatar
Plowman Plowman is offline
And you never told anybody till now. *Paul
Old 11-12-2011, 04:45 PM
It's one of those things that is habit now Out of sight out of mind.
Plus it's fresh on my normally absent mind, aas it has only been about 2 weeks since I adjusted the valves and broke in a cam...
Old 11-13-2011, 07:28 PM
Plowman's Avatar
You are telling the truth,happens to me all the time. Thanks. *Paul
