Old 02-05-2025, 12:21 AM
OneStopRestoration OneStopRestoration is offline
Default Delco Horn Rebuild
I had found some original 280 279 horns. Date codes are 69 but there so hard to read its not even worth mentioning what they are.
Neither one worked no matter how many times i smacked them. Repair included taking out all the rivets to split the horns from the electroncis. Both diaphrams were rusted swiss cheese. I found some donor horns and harvested parts including a new coil as I had a bad one. Riveted the units back together and painted. Played with the tone adjust some and there as good as new.
The Following 11 Users Say Thank You to OneStopRestoration For This Useful Post:
69M22Z (02-05-2025), Dave Rifkin (02-05-2025), dykstra (02-05-2025), gtomike1967 (02-06-2025), L78_Nova (02-06-2025), mhurd (02-05-2025), napa68 (02-05-2025), olredalert (02-05-2025), RPOLS3 (02-05-2025), scuncio (02-05-2025), Zman1969 (02-06-2025)
Old 02-05-2025, 12:24 AM
Default Parking Lamps
I wish all years were like 69s. Its so easy with this year to just blast and paint. The rubber boot was reconditioned and the copper bulb base blasted and finished off to look original. I decided on trim parts lenses. There very nice. I custom cut my own gaskets as I have struggled to find anyone that makes good replacements for other years.
The Following 14 Users Say Thank You to OneStopRestoration For This Useful Post:
66BoxNova (02-05-2025), 69M22Z (02-05-2025), big gear head (02-05-2025), Dave Rifkin (02-05-2025), dykstra (02-05-2025), L78_Nova (02-06-2025), mhurd (02-05-2025), olredalert (02-05-2025), PeteLeathersac (02-05-2025), ragtop (02-05-2025), ScottG (02-10-2025), scuncio (02-05-2025), Tenney (02-05-2025), Zman1969 (02-06-2025)
Old 02-05-2025, 12:16 PM
chevyman0429's Avatar
Originally Posted by OneStopRestoration View Post
I had found some original 280 279 horns. Date codes are 69 but there so hard to read it's not even worth mentioning what they are.
Neither one worked no matter how many times i smacked them. Repair included taking out all the rivets to split the horns from the electronics. Both diaphragms were rusted Swiss cheese. I found some donor horns and harvested parts including a new coil as I had a bad one. Riveted the units back together and painted. Played with the tone adjust some and there as good as new.
Rick,
I am in the process of restoring my horns for my 69 ss396 300 deluxe post car and I have a question does a gasket go in between both sides of the diagram? When I tore mine apart there was only a gasket on one side however the kit I bought has 3 gaskets in it! Thanks
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 02-05-2025, 11:24 PM
Originally Posted by chevyman0429 View Post
Rick,
Good question! I didnt use any. I believe they were put in place for the purpose weather sealing. I think the replacments i have seen are much thinner than original so there probably not gonna do much in the way of sealing. Its also hard to believe that with the gasket on one side it would seal anything on the orignals. I just sealed mine with seam sealer, let it dry and then painted them up.
The Following 2 Users Say Thank You to OneStopRestoration For This Useful Post:
chevyman0429 (02-05-2025), olredalert (02-06-2025)
